Trans relearn?
Whitetail Addict
Rockin' the stock tune
May 8, 2008
2,350
South Central Pennsylvania
How long does it take a trans to relearn after loading in a hotter tune? Also what is the recommended procedure, how hard to run it?
The trans is acting different, acting as though it is in tow/haul at times and not coming back to idle, I figure it is relearning the power.
paint94979
Beer Nazi
Sep 18, 2006
11,715
To shorten that RELEARN I would swap to an 01 TCM
Whitetail Addict
May 8, 2008
2,350
Thanks for the heads up. I didn't put the tcm in a fast learn mode, I guess that would speed it up some. In fact I didn't change anything in the tcm, I was curious if I should adjust anything i.e. shift points etc.
Thanks for the help.
paint94979
Beer Nazi
Sep 18, 2006
11,715
Depends what your trying to do some shift at 3600 3650 3700 and other personal preferences. An 01 TCM Learns a lot faster than an 03. Did you reset your TAPs?
