Allison 5sp: Trans Noise?
S Phinney
4,008
Quncy, Fl
I was testing the waste gate tuning this evening and limped the trans setting a P0790 code. There was a noticeable grinding and no gears. I cleared the code while rolling and had gears again. I idled back into my shop and looked for leaks. I saw one from under front of trans but it was fuel. I think I may have lost a CP3 also. Any ideas?
15,681
Your first post said no gears. That is not the C2 hub or P2 planet. If in fact you twisted the splines, you would still have 1-2-3. You would also have thrown a P0776/777 code if that happened. From doing some research; your p0790 code does not pertain to the 1000 trans. The normal/performance circuit is not activated in our TCMs. It has nothing to do with T/H.
S Phinney
4,008
Quncy, Fl
I did have no gears until I read and reset. I do have 1-2-3 gears. I did drive the truck for a slow test drive to see if any gears were effected. I do not have 4-5. I did not have any codes other than the one I posted. This occurred at the 4-5 shift at around 100 mph. It hits the rev limits and I stopped read codes while running, reset and idled back into the shop without any shifts. Either way it has to come apart.
