Trans leakin ?
rulonjj
50
I have ATF leaking out of the trans between from around the flywheel. Wondering what you guys think it might be.
Bako_Dmax
GTO Slayer
Apr 3, 2008
657
Bako
Its prolly leaking around the crimped part of the line and running back along the line. Or check that little brass plug on the front of the trans by the filter.
rulonjj
50
If it is the plug does it take any special tools to tighten. I'm not where I can look at it right now but it isn't the hoses. I just replaced all of those.
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
How hard is that to fix?
Have to pull the tranmsion out of the truck , then pull the bell housing, remove the stator assembly , then press out the pump housing ( were the seal goes in) , replace the seal and o-ring and then re-install, might be a good time for upgrades if you haves plans for any ?
rulonjj
50
I've been dreaming of upgrading. Guess I'll have to start saving some $.
rulonjj
50
I've been dreaming of upgrading. Guess I'll have to start saving some $. About how much money does it cost to upgrade? Anyone know of any good tranny shops in/around Great Falls, MT?
TrentNell
Jul 7, 2008
7,543
slc tuah
Might check with the boys at G&J diesel in Billings , dont know if they build them or not but Brad could point you to who they use anyway . You could take a Vacation to Cali and go see mike L he is the best in the buissness IMOP, IdahoRob ATP truck is in Boise Idaho, also very good, your location in your sig says Utah ? I could build it also if you get down this way often . I would make sure were the leak is coming from first though, no need to jump- to conclusions untill you know for sure .
