Trans issue
JustinD
Plow Truck
Nov 21, 2008
2,067
42
Tiverton Rhode Island
About 2 weeks ago I had my balancer pin shear off and cause a world of hurt on my truck, I got awesome tips and info from a few guys on here and got it fixed, I went to fix a "leak" between my trans and transfer case and found that I broke the rear housing!!!!!!.........
So I got another and we swapped it out, everything was going smooth......too smooth. Got the trans back in and checked and double checked all connections, filled it with fluid and go to back out of the garage. It backed out perfectly, I checked the fluid after a while of it idling outside the door. I tried to pull foward and it automatically throws an engine light (P1711) and feels like its slipping in 1st, reverse still works fine. We went back over to the shop last night to check every connector, they are all good, of course that would be too easy. So the next step is pull the pan and check the valve body, it is refering to solenoid E, in the past I had some 3-4 shifts that were hanging a little but most of the time it shifted fine. I was wondering if that E solenoid would have been acting funny before and now is junk? Also we did take the rear housing off, but the code doesn't show any info about C4 or C5 that is what is located there right??
Any info would be appriecated, seems like my truck is broken all the time!!!!!
I guess with power comes broken parts. Just recently I have broken an axle, water pump shit the bed, balncer issue, and now this........I can't wait to get it up and running again, it sucks driving an 88 2wd pick up with 250k on it while your truck is on the lift for 2 weeks.
15,681
It's allways E shift valve that is stuck and never the E solenoid. If there is crap in the pan the unit has to come apart. If it's clean, clean the E shift valve.
JustinD
Plow Truck
Nov 21, 2008
2,067
42
Its alive!!!!!!!!!!!.........We swapped out the solenoids and valves, cleaned the whole vb. The pressure switch had alot of gunk on the black buttons. We found some little flakes of what looks like clutch material?? Could be from the last time I fried the C2's. Gonna drive it until monday and change the fluid again.
