just bought the truck a week and a half ago...
2001 reg cab long bed lb7 efi live dps5 switch holley blue 1/2 lines....
guy said the trans. is built with only 5000 miles....
4 disk convertor(yes it is actually a REV MAX 4 disk "called rev max and verified they built the converter) red alto clutches, transgo ,....
truck done well for two days then in D would get to 3rd and wouldn't shift to 4th unless you let out of the throttle and then it'd go in 4th and 5th just fine.....
the trans doesn't slip once in any gear or kick out so i'm not thinking clutches.
couple days later it wouldn't even go to fourth and when it did catch in gear it was stuck in 3rd, no down shift or up....
throws p0700, p0734, p0735, p1721, p1723, p1875
its like when it goes to 4th its in neutral....
only thing other than that happened was the light around the D would flash every now and then.
i've read up and read up on this issue and have done the following thing to try to fix
NSBS new
changed fluid, spin on filter
changed Sol. B
took valve body out and apart flushed and re-installed
now only gettin
p0700
p1721
p1860
i've read up on all these but i can't pin point anything wrong.....
but if anyone can help more with this problem i would greatly appreciate the help,....
NSBS new
changed Sol. B
now only gettin
p0700
p1721
p1860
