trans blanket
RichLMM
699
North Kingstown RI
i just put a trans blanket on my truck but the only problem i ran into was the front driveshaft hoops are so close to the trans i couldn't get the blanket between the hoops and blanket is it ok to go out and around the driveshaft and hoops? or should i do something about the hoops?
JD Dave
In way over my head
May 19, 2008
2,388
Caledon, Ontario
I wouldn't go around the driveshaft. Mines a really tight fit and I had to move my shields a little bit but it should work. I'm guessing there shouldn't be much differnece in years of trucks.
RichLMM
699
North Kingstown RI
i took the hoops off and got it up against the trans but it still touches the driveshaft!!!...was i supposed to take everything off the trans put the blanket on then reconnect it all?
Woody87
58
Mt. Vernon, IN
I have the same blanket, my shaft actually just barely touches it in 2 places. I was told the thin tin like covering on that side of the blanket was to protect it from rubbing. Been on two years with no issues.
RichLMM
699
North Kingstown RI
yea tim at the switch and towards the front a little bit...i put that chrome heat sheild stuff on the pass side...i figured it was to keep the heat from the exhaust off it....
