Got a 2002 GMC with 238,000kms on it. All stock except for Hypermax tuner, 4 inch exhaust, and drop in air filter.
Keep getting codes: P0847, P0872, P0875
Been reading up on these codes from on here, and done some of the things you guys recommended. Trans level was low, but topped up.
Took for a test ride and this is what it does.
From a start the shift indicator doesn't seem to know whats going on. I put it in any gear and it tells me that i'm in third. It bangs really hard when i select a gear, reverse will just disengage, and then engage. As soon as i clear the codes they come back, sometimes it puts it into limp mode, and other times it doesn't. Then yesturday it worked fine until i stopped the truck and shifted into reverse. Then it started all over again!!!
So i have dropped the pan, fluid was dark red, but smelled ok. Nothing in the pan, magnet had nothing on it. Changed both filters and put in new fluid and still the same!! Checked harness in the pan, OK. Tore apart valve body, and all looked good!! PLEASE HELP!!!
