My tranny will hit 200 degrees cruising around town barely giving it hell. What could cause it to get so hot??
Tow haul in town will net you 1 to 2 miles to the gallon better and it will keep the trans locked up instead of slipping which I can only assume will help keep the trans a smig cooler.A deep pan will help some also.
After every summer, or even late spring, I feel like it is a good idea to clean the fins of the trans cooler out. This is the time of year when the most stuff is in the air, like dogwood seeds floating and insects, between the two your trans cooler can get pretty caked full and not allow the proper amount of air flow throught the core to do its job to its potential, then add a greater ambient heat index(called summer) and its just enough to get your trans fluid to its "breaking point" so to speak, where it can't absorb and shed the heat well enough. Imho
Just my .02
I agree 100%. Its amazing how much crap comes out. I actually got some screen like for a screen door and mounted it behind my grill. Not as fine but enough to catch crap. Seems to work great.
