Conversion in! Install went good.Only one hitch,BANKS SIX GUN W/PDA DOES NOT WORK WITH THIS CONVERSION!After install started truck went for "test drive"BANKS went through gears fine,then after TC lockup it happened...Trans slip 4095! Tuner went into fault mode.Went home,turned truck off,tried to start again...started then stalled.Removed BANKS,everything is well.Now for the conversion,after tranny relearn truck runs great! Shifts are smoother,ride is quieter,downshifts are hardly noticable.Going to Florida in a couple of weeks so I'll report back with MPG gains...Thanks Suncoast.:hail2:
