Tranny Line Question....
duramaxdiesel
Dmax Nut
Oct 23, 2008
1,378
47
Montreal, Canada
Ok so right now I'm in the middle of bumf&@k nowhere and my tranny line is leaking. It seems the bottom line has been rubbing for some time now on the oil pan and finally rubbed through. My question to you guys now is can I just cut the steel line and put a piece of hose there with two clamps to get me home? What is the line pressure? Will the rubber hose hold the pressure or will it blow off?? Any info is appreciated!
Thanks!
Nick
blackdirtymax
Apr 15, 2010
825
augusta, ga
Pull the line and cut out the bad section , then flare the two metal ends and have a jic hose ( hydraulic hose ) made up . Make sure you get two brass flared fittings to go on your metal lines before you flare it . I have made this repair before , works great !!!
Built motor , duel fuelers , 60's overs , gtx4202r
15,681
Do not use rubber hose. Pressure can spike to 200 psi and will blow hose off. Try using a compression fitting ( 5/8 ). It may be long enough to cover the length of damaged piece line you cut off. If you have to use hose, double clamp it and keep your foot out of it. Good luck.
