LB7: tranny leak when running
20chevy04
Aug 17, 2011
295
Stuart ,FL
ok so im a little stumped.my tranny wont leak when its not running.when its running and a little warm it has a constant drip thats dripping right above the cross member i believe where it connects to the transfer case i have a video but dont know how to post it and dont think it will help at all. the only thing i can think of is to pull it and replace the seals.
20chevy04
Aug 17, 2011
295
Stuart ,FL
checked fluid when its was running an hot and it was right at the mark a little less but hasnt dropped since last time will check tcase an harness tomorrow
20chevy04
Aug 17, 2011
295
Stuart ,FL
fluid in tranny is good and in tcase also the plugs on the tranny are all fine no wires cut or showing and everythings plugged in.
15,681
You have to disconnect the main harness connector to see if there is fluid leaking at the connection.
