to give some history,
broke input shaft, fixed
broke output, fixed
twisted hub in turbine in converter, fixed
started leaking fluid out of bellhousing after a month, pulled trans had converter checked it was good checked all the bolts and put new seal leak stopped for a few weeks.
then starts leaking bad almost pouring, pulled tranny had converter checked again(good) pulled bellhousing and pump. replaced pump seal glued all bolts new bushing and seal. starts pouring on test drive.
I don't know what to do, there are no shops around me that do alli. tranny has gmax 5 kit with 1058 converter.
broke output, fixed
