Tranny Codes: wont go into gear
Dec 2, 2006
1,696
TN
My friends truck would not go into gear this morning. His truck is a 06 LBZ like mine. Stock tranny with a EFILive tune (around 100HP). I pulled these codes:
0751
0843
0873
0700
I started it up when I got there and it worked fine, so I cleared the codes, it came back one more time. But after clearing them for the second time, I drove it and everything is fine. Shifts perfect, TCCSLIP seems ok also.
Any help is appreciated! Thanks.
15,681
P0843 is the one you're concerned with. Sounds like a bad PSM. TCM is not getting correct feedback on shift valve position from the manifold.
Dec 2, 2006
1,696
TN
You think our best bet is to start there? Replacing the PSM?
fast03
1,201
61
Rancho Cucamonga
I had the same problem on my 03 with all those code and more. Pulld out of the drive then at the first stop sign it went into neutral. I cycled the key a few times and it has not done it since. I thought my problem was because the truck sat in my sloped driveway for almost 3 weeks, so I thought maybe the converter drained.
