Tranny and Code help
Iceman56
Jan 19, 2009
867
Madison, SD
I took the tranny out of my truck to get at a piece I broke trying to install RDL manifolds and up pipes.
I did nothing with the tranny but drop it then put it back in. I tried taking it for a drive and at first it popped into nuetral and said "shift inhibited" or somehting. Then I took off again, it shiffted real hard then I got a code I am getting now P0717: "Input/turbine speed sensor no signal" does that code have to do with the tranny??
Now the truck won't shift out of first gear and when you shift from Nuetral to reverse or nuetral to drive is slams into gear:confused:
Can someone please help me here I checked all the wires they all look to be plugged in unless I am missing one?
Thanks
Mike
MACKIN
Smell My Finger...
Aug 14, 2006
3,948
Connecticut
Check all your electrical connections to the transmission. Top of the transmission
calabria69
Beerstud1
Oct 8, 2008
375
Santaquin, Utah
My friends lbz just did the same thing, he grounded out the tcm with a speaker wire and is working again....he didn't pull the trans just blew something within the tcm.....:confused:
Iceman56
Jan 19, 2009
867
Madison, SD
I found it.. Didn't have the wire on top driverside of tranny even plugged in.:screwy: lol funny what you can do when when you take a break and come back and look again, I must have looked for a half hour for that wire the first time
