Its a 17ft bumper pull...got it from a friend to move with...blinker/break lights work fine.. just keeps blowing the 15amp park light fuse as soon as you hit the lights..so far I've worked out it not being the plug, trailer brake wiring and the little trailer battery..ran a wire all the way to the back of the trailer into the park light "brown" wire from the park light terminal on the truck plug..still blowing the fuse..pulled all the lights..and there mounts..also pulled the cover off the top inside back of the trailer to check those wires from the inside..is it possible the fuse is too small? I'm all out of ideas
