Coolant temp shows maxed out hot as soon as you turn the key on. Sensor is new and ohms out as it should cold. Checking the engine harness (which is nearly new) the multimeter doesn't find any short. The pins/slots on the bale connectors are clean and tight and not bent/damaged (including the large connector that attaches to the ECM with PIN 74 (which I believe is the correct one for ECT on the LBZ). I will pull the ECM out next and inspect that pin. If it's bad or if it's good, any suggestions or thoughts?
