towing why so hot??
dmaxed 67
Jan 3, 2009
54
we went camping and pulled our 19' travel trailer with our usual gear and going up the coquihalla,wich is pretty good grade the engine temp shot uo to like 230 before the clutch fan,wich dropped it about 20 degrees fairly quick aslo the 97 c here is a steep climb,I ciudnt go fatser then 90 km an hour without 1300 degree egt on the steep parts anyone else show these numbers 06 lbx cclb
lotsofmiles
Father of the Van
Dec 4, 2008
3,097
Michigan
X2, was it staying in 6th or did it drop to 5th.
19ft shouldnt be an issue unless you've loaded it with bricks or something
dmaxed 67
Jan 3, 2009
54
Inever tow with any tune period never have was told its not wise with abasicically stock tranny so thats the way I have alwyas towed,as for gearing I have a heck of time telling what gear Im in,at the best of times
dmaxed 67
Jan 3, 2009
54
not high maybe 1800 honestly I will have to pay closer attention and I apologize for thats ,as thtas kinda important
lotsofmiles
Father of the Van
Dec 4, 2008
3,097
Michigan
Sometimes on hills these trucks like to stay in 6th, but the temps start climbing esp with a trailer in tow. I've noticed that if its a long enough hill and the temps are climbing, get it to go into 5th raise the rpms up. But its usually just my egt that climbs not the coolant. I really cant even remember the last time, or if I've ever heard my fan kick in on the truck. I know I hear it on the van when pulling but the step child doesnt count:D
dmaxed 67
Jan 3, 2009
54
ok thanks for the info the hills are pretty steep without aload I race up them 140 kmh no problems,my trailer dry weight 2000kg before the mres gets the food and clothes not to mention our zodiack 15 hp merc,and come to think of it,I had water on board for some dounb reason I fill the tank before we left:eek:Im not well
9,905
151
I would run 5th up the 10 mile hill for sure, and maybe even 4th depending on your tire size. Keeping the rpm's up will raise the trans temp a little, but the egt's will go down.
My fan doesn't come on unless the A/C is running and it only came on with the coolant temp once and that was when it was close to 225F as well. This was pulling my 8000# holiday trailer through the west Kootenay's-not running empty
Also, you could have a blockage between the intercooler and the radiator. Sometimes the IC needs to be removed and the radiator washed out. Bugs and mud are quite often the culprit!
racinmike77
Sep 14, 2008
1,029
MD
X2 you dont need 6th gear. 6th is for running unloaded on flat ground not for towing. If you are traveling up a hill with a trailer at 90kmph you should definately be in 4th gear.
serpa4
Feb 5, 2007
402
Happened once last week. I had about 10,000-11,000 cargo (truck camper+boat). EGT were fine, but temp started creeping up (230-240) as did the trans (200-210). Not sure why it did. The hill wasn't even that steep and it was only like 80-90 degrees out. Have Mike's trans cooler and Bee Oil Cooler as well! This was with the factory fans and shroud in place (usually run electric). Then on hotter days etc, temp never hit 200 again. Pretty strange.
FMOS
Hard Up
Nov 19, 2008
352
Fort McMurray, Alberta, Canada
I took the grill inserts out of my truck. In the winter, I need them to make any heat, but if I hook a trailer up I need to take them out or else the fan wants to run all the time.
I'm going to go out on a limb and say it was the 40°C temps that was causing some heat for you.
I just drove the rogers pass on friday afternoon, unloaded, and my fan was running regularly. OAT's were between 25 and 35°C. I was running a hot tune though, probably accounted for some of the heat.
I towed the boat from Salmon Arm to Vernon down hwy 97 on thursday and my fan was running. Engine temps didn't get out of line on the stock gauge.
Definitely throw it into 5th when towing, and into 4th for the hills. I usually get the rpm's up to about 2200-2500 to manage my egt's.
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
x2
