LBZ: Towing performance
Trotorx2
699
71
Beaumont, Texas
I've got some questions and not sure where to post so I thought I'd start here, move if necessary.
I have a 35' 14k toyhauler I pull regularly and I'm thinking about some mods that will help with mpg and egt's. I'm already working on a trans upgrade and EFI DSP5 and was wondering if going up a size on the turbo would be worth the expense?
I'm currently running the Predator and have no issues with power but it tends to get warm even on the tow setting. I would like to keep the VVT style turbo. I looked around the vendors at twins but think the expense and difficulty at getting to the fuel filter would be a problem.
Not going to be pulling or going to the track just a DD/tower.
Any suggestions?
Trotorx2
699
71
Beaumont, Texas
Here in the flat lands of east Texas going over tall bridges I'll see between 1200-1300 degrees in 5th maybe that isn't too warm but I want to travel up north thru steeper grades and not have to worry about burning it up.
dmaxfireman
'Can do' kind of guy
Apr 8, 2007
2,329
CT
predator tunes are not designed to run cool. you should get out of OD to cool off your egts and save your trans as well.
Redbowties88
Sideways > Straight ;)
Aug 24, 2009
1,943
609 New Jersey
with a decent sized load those temps aren't bad at all, running a near continuous 1300 should be no problem and even high number for short periods is ok.
there is probably some room for improvement with better tunes but i dont see a whole lot.
try the stock tune and see what numbers you get
Trotorx2
699
71
Beaumont, Texas
I have tried stock it pulls ok my mpg went way down 8mpg on flat roads. My temps never got over 1150 going over the bridge that saw well over 1200 with the Predator. My tuned mpg are between 10-11mpg.
I just am worried pulling some of the grades thru Arkansas and Tenn/N.Carolina.
RENODMAX
Dead Wrong
Mar 4, 2008
3,602
EFI live, larger intercooler pipes, downpipe, and uppipes if you can swing it. The larger piping gave me a good EGT drop. Ive ran numerous turbos and now back to the stock charger due to being a broke college kid, but from my experience the intercooler pipes and downpipe i built gave me a good 100-150 egt drop on my LB7. I think if youre towing a heavy load and your egts are 1000-1200 you would be sitting pretty well.
Redbowties88
Aug 24, 2009
1,943
609 New Jersey
well i know it would be a little of a pain, but i would just try it with the predator and if you become uncomfortable with the egt's you can always stop and change the tune on the next pull off..
i would be scared till i hit 1400 and stayed there for a little while
llybyppe
May 11, 2009
238
Why don't you start with doing like boost tubes,down pipe,up pipes and a bd exhaust manifold. All of that will not only help out egts but also help in performance and will be way less then a turbo up grade.
RENODMAX
Dead Wrong
Mar 4, 2008
3,602
read my post :thumb:
BD manifold will not matter. If you do manifolds contact Rick at profabperformance.com
Trotorx2
699
71
Beaumont, Texas
Ok I'll look into this first. I didn't realize 1200-1300 wasn't too warm. Maybe with a good EFI tow tune it will be better also.
Thanks :thumb:
Trotorx2
699
71
Beaumont, Texas
I'm going to look into the downpipe, manifolds, up pipes and as much as I don't want to give Banks any of my money maybe boost tubes while the trans is out. That and a good EFI tow tune I guess will help the most.
RENODMAX
Dead Wrong
Mar 4, 2008
3,602
Call chad at alligator performance. Hell take care of you and they make boost tubes.
