Tow Haul & OD Lockout Malfunction
millerman04
< The Man Cave
Jul 14, 2010
1,039
Clearville, Pa
As of late i've noticed my tow-haul and OD lockout wont work. I've checked the orange wire the runs down from the shifter and into the column. It's not broken. Now i cant get the cover back over the column. Damn plastic crap!! :mad: Is there a fuse somewhere to check? Thanks!!
millerman04
< The Man Cave
Jul 14, 2010
1,039
Clearville, Pa
I figured out how to get it to work. If i pull the shifter back and then hit the button it will work. Is it that hard to change the shifter?
jraymer
<--Tree Hugger
Oct 31, 2008
1,421
Las Vegas, NV
Ya my tow/haul only works in park, in any other gear it won't. Haven't had time to pull it apart and figure it out.
13,712
773
Changing it is pretty easy. As I recall, it is only held in with one bolt, but it sounds to me like it is a broken wire.
403turbo
<--It's whats for dinner!
Aug 3, 2009
80
DPRNY
haha this is funny, mine started doing the same thing last week. If it doesn't work I just pull it toward me an inch and hit the button. So far that is working. Must be a wire chaffed on something and grounding out.
millerman04
< The Man Cave
Jul 14, 2010
1,039
Clearville, Pa
same fit mines doin. and the same solution too. :happy2: im not alone after all!!!
red1977
Nov 15, 2010
786
46
Ogden Utah
On mine there were black rubbers that held the wire to the steering coulum and it was broke right next to that. I just soldered the two wires back together and put heat shrink around them and have not had any problems sens then.
