Torsion Bar Key Question
MaxFarmer
<--Heavy Smoker
Jan 22, 2007
1,251
45
Albion, Nebraska
I was running "green" keys before I put my lift on. I just left them in with the lift and didnt think too much about it. When I took them out (to pull the front diff I dropped the whole front crossmember) I got about 18 turns on the bolts. BUT, I was loose from the keys about 10 turns into it. I could pull the key keepers out by hand once the bolts were out.
Should I put my stocker keys back in with the lift I'm running? I remember before that I had to make a contraption to stick my puller into to keep it on the crossmember and compress the key to get the keeper out. How the hell did I lose all my spring? I wonder if my stockers will still let me slide the keeper in by hand? I'll try that tomorrow.
What do you guys think?
bullfrogjohnson
Big Girl!
Nov 20, 2006
4,167
Locust, NC
Factory torsion bars will unload after time. I would try to put your stock keys back in because the green keys put alot of unneeded stress on the front end and can cause front end issues when doing a 4wd launch. I had them in my truck and removed them.
Jason these keys is probably why you busted you cv joint a while back. Those keys will never let your front end sit at a negative angle like you need when doing 4wd launches to keep the front end together
MaxFarmer
<--Heavy Smoker
Jan 22, 2007
1,251
45
Albion, Nebraska
Travis,
Thanks for the insight. That re-affirms what I have been thinking. I just know that before I had a helluva lot more preload than I do now. I'm puttin on new beefy tie-rods so my alignment is gonn have to be done again anyway.
Thanks,
MaxFarmer
<--Heavy Smoker
Jan 22, 2007
1,251
45
Albion, Nebraska
I really like the stockers better. Seems to ride a LOT smoother again. Of course, I have nothing to compare to except my 1-ton 6.5 which is rough as hell. It sure took a lot more to get them keys back in than it did to get the greenies out. I wonder if something was not in right before, like they were 1/6th of a turn from being indexed into the keys like it was supposed to be.
