Installed a brand new Precision converter and fresh trans on Friday. When I ordered the converter I specified that I needed a converter that I could brake stall at a minimum of 2500rpm to properly spool and leave the line. I spent time explaining my set-up with their sales team so I feel confident that we were both on the same page for this order.
I went to a race on Saturday and made a few shake down passes and immediately noticed that my truck would start pushing hard on the brakes around 1850rpm. I got a good data log of the burnout, stage, and launch and the most rpm I could get was 1859rpm at 9.4% throttle position. At that throttle position I am not making any boost and torque numbers are tiny so I couldn't get a decent launch or get up on the turbo at all. We also had just upgraded the entire braking system with EBC yellow pads and freshly turned rotors to make sure that was in top shape.
I plan on calling Precision tomorrow but I wanted to get some opinions on what my expectations should be from the converter. I assumed that I would be able to get a lot more stall rpm than 1859rpm. Are there other issues that could alter/affect the brake stall? The converter locked up right at the top of second gear and the trans is also working fine (no codes).
The part number on the converter invoice from Precision is 303438-3HS. Has anyone else ran this converter?
I have a SC 1055 that I can swap in but I wondering if there is something that I am simply overlooking.
