Topkick/pickup Allison
dracing70
SH--- GETTING EXPENSIVE!
Jun 12, 2007
1,210
45
mantua, oh
I thought I asked this before however I can't find the post. Can u use a Topkick ally in a pickup and if so r the changes needed extensive. We have a Lly Topkick ally that we wanted to use in our 08 pickup?
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
Need to change the bell housing.
And also...what year LLY? 04-05? If so, you'll need to change the valve body too because the 04-05 LLY topkick will be a 5-speed trans/VB
dracing70
Jun 12, 2007
1,210
45
mantua, oh
It's a built Trans. Hence the reason for change. So if we swap vb we should change the shift kit parts also correct? What's the diff with the bell housing?
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
2500/3500 trucks used the standard 90 degree GM bellhousing bolt pattern, 4500/5500 used the round SAE bellhousing bolt pattern. If it is a 5 speed ALLISON you would have to swap bellhousings, shift shaft, IMS, and valve body to make it work, but it would seem counter productive to step back to a trans that doesn't have the improved internals and C1/C2 drum.
DURAMXD
BOB SAGET!
Apr 24, 2012
348
Wichita, KS
Here's what the 4500/5500 flywheel housing looks like, shows the SAE pattern as mentioned above:
dracing70
Jun 12, 2007
1,210
45
mantua, oh
Yeah that's a bit diff. So u guys don't think it's worth it even though its built. We r selling the Topkick and just could not c selling it with it. If we could use it. It don't really add value
15,681
Give me a call and I'll give you all your options.
