top ear on starter
WTF
slow and broke
Nov 20, 2006
229
Wasco,CA
it just snaped off and the starter fell out today and i was woundering if this has happened to any body else i will post pix tomarrow
9,905
151
Yes someone else has had it happen to them on this site but I don't remember who. Maybe it was Maxfarmer......?????
Happened to him 2 times IIRC.
Don't know why though:confused:
stacks04
792
Terryville,Ct
we had one in the shop about a month ago. the ear wasn't broken complete, but it was cracked dead center of the bolt hole, and it traveled up into the body of the starter, probably wasn't long til it broke, but the thing would not start the truck. the torque must of been moving it enough to sound like a broken flywheel tooth.
15,681
233
I wonder how many of these cracked starters were removed and reinstalled previously prior to the cracking? I have removed and installed over 600 starters without a problem and have never seen a cracked one. Just a thought.
stacks04
792
Terryville,Ct
well, mike the tech doing the job had ordered a flywheel. had installed the flywheel and we were putting the starter back in, i help him do the t/c bolts while he sits underneath spinning the engine, so i grabbed the starter to set it in place for him while i was right there and i noticed the crack. i wonder how many flywheels have been chewed up due to the crack and the stater not being stable.
15,681
233
Good point.
RKTMech
Idiot with a wrench
Aug 18, 2008
936
The Norco's
I'v come across loose starter bolts before. Some finger loose but some were just not tight enough. This condition could cause the starter to move around a bit and that could lead to something not so good. Havent seen a cracked or broken one yet.:joker:
WTF
slow and broke
Nov 20, 2006
229
Wasco,CA
this is what it looks like
Skyhigh4by
Goin to Poochisloose
Apr 13, 2008
408
Powell River, BC
My starter seems to miss every once in awhile...I should get under there and take a look eh!. Actually a friend has the same truck and his does it to. Maybe once a month or so
WTF
slow and broke
Nov 20, 2006
229
Wasco,CA
it snaped the bottom bolt so i need a new one any one know where i can besides the stealer
nar
Now with less _
Feb 7, 2008
199
Wyoming
I have a starter just like that. Just needs a new mount plate. Hell I actually have that starter on my truck with the mount plate from another starter on it. Need to find a place to just buy the mount plate, it's easy to swap it out.
Mine that fell out had been off about a year before that, replaced by the dealer. The bottom bolt rattled loose and fell out, then the top of the mount plate broke.
