2007 (LBZ) 52K miles with an EFI live 100 HP tune and 4" exhaust with no cat. I have been running this tune for 3 years with absolutely no problem. I have noticed lately that under moderate aceleration unloaded the truck will boost way more than it used to. Half throttle puts the boost up around 20 psi. If I am loaded it will max about 28 psi. In the past the only way to get the boost that high was to really put your foot in it. New fuel filter and air filter. MAF is alo been cleaned. No trouble codes at all. Also noticed EGT's are a little higher as well. Not sure where to look next. Any help would be appreciated. Thanks
