LLY: To port or not to port
THduramax
Will it ever end!
Aug 15, 2012
407
Flaherty, ky
Doin a motor build.. Goin for 800 to 900 ponies.. Stuck whether I should spend the high dollars for porting or not.. Does it really make a difference or what.. Iv heard mixed reviews about doing it.. And let's stay on topic with this one!
1,866
800 is pretty common for a built motor without porting. Matching the turbos, fueling and tuning is very important, you just cant throw parts together and expect good results.
BTW, to answer the tagline under your username....no, it never ends. :roflmao:
ecc_33
Junior Member
Aug 10, 2006
1,925
Amanda, Ohio
I agree. I run stock heads and cam. Buy a good set of valve springs and run it. Put the money you save to a bad ass turbo(s)
2006 LBZ
Feb 8, 2011
195
Calgary, Ab.
Even though I have had little to no luck with ported heads, I still vote for it. I had a set of hand ported LBZ heads by Curtis Halvorson on my stock motor and noticed lower egt`s, lower drive pressure, and quicker spooling. Made 670rwhp with nitrous on a stock turbo and sticks. Wish I still had those heads.
From what I understand there is going to be some major improvements in dmax heads this coming year though.
Utahski
Oct 20, 2008
546
Northern Utah
If the cost isn't a problem then do it. But you can go pretty good with stock porting and heavy springs. I've seen Chavis's truck run mid 10's with stock porting and cam. Matt (MaxPowerLB7) ran mid 10 with very mildly modded heads and stock cam. Both trucks were over 1000 depending on which dyno. Before the black truck was built into a racer, Trent ran 11.0 on a stock engine / heads /cam with only tune and turbos.
