LLY: To high Rail?
skintback
Take this one to church
Mar 5, 2007
919
Florida
I get to high of rail psi P0088 now on my 05 lly with dual pumps what tables do i need change to get rid of the limp mod that limits it to 20K when the code is set?
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
Sonny
When ever i have a code issue the best thing to do is type the code into the navigator on the top left of the tune file :)
So if you type in P0088 it goes to the DTC tables and then goes to C1807
C1807 is the table to change ;)
the DTC tables not so much, your best to elimate the issue rather than hide it.
Simon
skintback
Mar 5, 2007
919
Florida
No i didn't want to hide it i wanted to fix it the right way
C1807 was at 167mpa everything else was moved up hope this was the problem
Thanks
