tires
jagood01
Mar 29, 2009
i have an 05 duramax and i gotta loose those stock tires...whats the biggest tire i can put on it?
n0useforaname
knows your mom
Apr 16, 2009
72
I've seen people run 295's on stock wheels, but don't recommend it. Just remember though, a stock wheels is not made for a 285, and it can damage the wheel. Not saying it will happen, but it can. You also might have to crank the T bars a bit or get a leveling kit as well. And if you do any trimming, it will be the on lower plastic valance on the front bumper.
maxaholic
1,876
40
Central, Texas
I've never seen a stock wheel damaged from an oversized tire. Hell I even ran 305s on my factory steel wheels and they're only half inch wider than PYOs.
Idaho CTD
Junkie
May 28, 2008
179
Idaho
I think he meant cause premature wear on the tires because the rims are too narrow. I run 295's on mine but it rides pretty rough with the torsion bars nearly all the way up. It will rub my inner fender but it clears the bumper on my LMM. I'll put 285's on it when these wear out.
