Help: Tire/wheel help please!
Mccullj
Jul 15, 2012
13
Hey guys. I bought a truck and it had 31x12.50x20 tires on it. They are hitting my bumper only on the drivers side and hitting the body on both sides. What can I do to be able to run these tires and wheels. I have already installed new torsion keys. It helped quite a bit but not enough. Ruined my ride too. If I dropped down to an 18 inch wheel and put my stock torsion keys back on, what is the biggest tire I can run? Is there any tire size I can run with the 20 inch wheels at stock ride height? I'd really like to take my torsion keys out. Please help guys.
rickettzusaf
Nov 30, 2011
276
Goldsboro, NC
Are these 31's or 33's or 35's?
I ran a 285/55r20 (33x12) with stock keys all the way down and a 3 inch drop shackle with a fender mod and then didnt rub. My wheels were 20x10 with a -44 offset so the middle of the front tire was on the edge of the fender flares.
z79outlaw
793
Salem WI
If there 31's and not clearing it sounds like a wheel offset issue what wheel are on there? Minor trimming might be needed I ran 33x12.5s on 16x10's on a 05 GMC with barely any trimming and dropped bars.
rickettzusaf
Nov 30, 2011
276
Goldsboro, NC
I have 265/70r17 now which are 31-31.7's with my 3/5 drop kit on 17x8 wheels and mine dont rub at all and I can even put a hand in between the tire and fender with the tire turned all the way.
Hot COCOAL
May the farce be with you
Jun 9, 2012
4,433
31x12.5 should never rub? The wheels MUST BE STICKING WAY OUT to rub. I would look into another set of wheels, the ones on there now are probably meant more for a solid/ straight axel truck.
You need a mid drive wheel with a min of 4.5" of back spacing and a max of 5.75" to keep the rubbing from happening, or just start trimming.
dbev24
390
Darlington pa
I'm running 31 and mine is dropped down in the front and doesn't rub. I did have to trim the bumper alittle. But it's all in your offset to.
Janimal444
354
Salem, NH
I run 285/50/20s with no rubbing issues at all, even when I have my torsion bars dropped at the drag strip i have no rubbing issues.
Not to beat a dead horse, but try to find out your offset/backspacing. There is no way a 31" tire should be rubbing if it had the proper offset.
Mccullj
Jul 15, 2012
13
Sorry guys. Been offline a while. They are 33x 12.5 tires on helo wheels. I will have to check out which ones and try to get specs. Thanks for your help.
silverado9503
Aug 13, 2012
Burnham, Pa
Hey guys i got 20 inch wheels with just 32x11.5s right now but my problem is that they are not a tire for a 2500 i wanna get 275/65/20s which are load range e but i dont wanna crank the torsion way up. will this be a ton of cutting?
leehype
Drunk with a Jeep problem
Aug 16, 2012
I bought my truck, it came with 275's, no rubing. Stock hight, and filled the wheel well, I would guess there was 1/2 inch clearance or less though. One of the tires started to seperate, so I went with a 265.
