LLY: Tips for removing upper oil pan?
thunder550
1,176
Phoenix, AZ
Engine is out of the truck, working on pulling the upper oil pan. I got all of the allen bolts out, and got one of the two flywheel housing bolts removed from the pan. I can't quite get a socket in on the second bolt. This is the driver's side. Any tips? I've read a couple threads where people have gotten this bolt without removing the flywheel. I can fit a 16mm socket in but not a 17mm, it's that close.
JDT4430
75
I was able to gind down a 12 point socket and make it as thin as I could and got it in there. I also heard of someone using a hammer and chisel. Also on one of them I took a impact swivel socket apart and used it becuase it was short enough to go behind the flywheel and over the bolt. Just used a punch in the hole were the pin goes that normally holds it together to turn it.
