LMM: Timing Map Feedback
02CCSB
Built
May 24, 2012
391
Winnipeg, Canada
I've been battling an LMM that's just doggy in the low end.
Played with the timing calculator today & came up with what you see below. It looks awfully aggressive to me in the low range. Just looking for feedback if this is normal or not on an LMM with a pretty aggressive tune.
I have this in the Med Alt A table
PureHybrid
Isuzu Shakes IT
Feb 15, 2012
3,496
477
Central OH
That timing won't hurt anything. I can't see cells below 45mm3 but I wouldn't hesitate to run that map. You can back it down if you want, it may just run a touch hotter when rolling in the throttle.
SickLL7Crenshaw
Billy The Kid
Mar 10, 2013
1,088
Mexico
Why do you assume its in the timing that's making the truck run like a dog down low?? So many different variables that it could be. What's your PW with that timing map? You have a drive pressure gauge in that lmm your tuning?
02CCSB
Built
May 24, 2012
391
Winnipeg, Canada
Drive pressure no, rail pressure is good.
I'm chasing the timing table because the one that is on the truck is drastically different from the one above, approx 6' on average in the low end.
The truck is just flat and gutless until about 2000RPM
02CCSB
Built
May 24, 2012
391
Winnipeg, Canada
Fuel pressure table is stock.
pw maxes out around 3100, comes up smooth.
My biggest concern is whether or not I will hurt a stock motor with this type of table before I start to even try to dial it in.
