I wanted to see if I could lower timing (lower than stock (-3,-1 degrees)). To help spoolup faster
I have also been working on trying to make a minimal or very low smoke tune. Which is very hard with a 500rw tune becuase there is not enough resolution in the MAF limiting table in the cells above 2g/cyl.
I know this test isnt a very good way to show how timing changes spool but it was the best I could do. I also did more test with almost the exact same conditions and exact same timing and fuel and saw the same result, about 2/10s of a second faster when timing is lowered -3 - -1 degrees in the idle-2300rpm ranges.
This is with timing advanced from about 1-5 degrees.
This is with timing about -3 - 0 degrees.
What is everyone else seeing for spoolup time? (idle to full commanded boost)
