I have decided to give more information on some of the projects I am doing that might give a little info back
I have been working with Gates on the GT3 and PolyChain belts to drive the CP3 Pumps. I underdrive my pumps because of the rpm range I run my motors.
The reason for the positive drive ( cogged belts ) is critical, and not apparent unless you data log at a much higher rate then EFI is capable of. EFI live log's at 100 samples per second I data log at 1000 and some time 2000 samples per second.
With ribbed style belts you have slip when you start leaning on the pump's. This small percent slip may not sound like a problem, but I believe it is a cause of rail bounce .
These pumps are variable positive sometimes displacement pumps and a small percentage of slip causes the pump to wig out slow down even a small amount, the fuel deliver changes. The FCA's will catch and causes a drop in fuel delivery, and the ECM starts to cycle to balance this. This is the cause I believe of rail bounce
At 1000samples per second you can see the action of the FCA's and VCV BS,and look at that in relationship to actually fuel pressure.
I drive my 2 Exergy 12mm stroker pumps off the cams at 67. % of normal CP3 speed.
here is some pictures of the parts I built .
I turn the wrenches on my car,
here is some pictures of the parts I built and the results
