Well I pushed it till she popped. Number 6 piston cracked right through the middle. Got it all apart almost down to the short block. Here are some picks of the pull and damage. It didn't score the wall bad at all. Can barely even feel it so probably just a light hone. The build will be Carrillo rods, finger piston low compression, arp hardware (have head studs already so will get main studs), clevite bearings, key cam and crank also balance, weld my water pump, new oil cooler and oil pump heard its recommend for when it lets go (guess if a piece of metal gets in there?) and that will be it for the bottom end. Heads will be stock maybe some springs but not sure yet.
