I just got my 200DX last week & it currently can do more than I can. I had just decided on one & then Turbo Buick 6 gave me a recommendation so I knew I was on the right track. I did not get water cooled (even though I had originally planned to) as I was talked out of it by a few people (including the salesman)since I will not likely weld continuously for more than 20min. at a given stretch. 1/4" steel & 1/8" aluminum is probably the thickest metal I'll typically weld. The extra $1000 looks better in my pocket anyway.
Thumb control is neat, but I keep turning it the wrong way..... clockwise has always been off to me.
With all the bells & whistles, I'm still trying to see what works best. So far I have not got the hang of high frequency welding, as I seem to weld better at 60-70 hz.... but I plan to experiment a lot more.
Practiced with the pulse function & my welds seem to have a coarser appearance, but it really helps penetration.
As for the AC balance adjustment on aluminum, that works really nice. I started out with standard AC & as soon as I moved it towards the higher numbers, I could immediately see where I will use this. Welded at 80/20 for a while & got some realy nice looking welds.
Tried some very thin metal (around 20ga) & was welding it together with about 3 amps. Only problem was, I did not have the helmet sensitivity up enough & suddenly I was staring at an unfiltered arc. After I quit seeing blue spots, I adjusted the helmet & tried again.
I'm slowly welding every scrap piece together into one big Frankenstein creation, by trying to weld different thicknesses & at multiple angles. Then I try to break it to check the penetration/stength & then I'll attach another piece. Welding 18ga to 1/4" at a 90deg joint for example took me a little while to make it look nice.
I can see my MIG will get a lot less use now.
