LB7: Throttle Position Sensor Bad?
WisconsinHick1
Mar 11, 2009
1,231
Minnesota
I have had a few odd spikes and drops in my TPS graph while building boost for a sled pull. I have not heard too much about TPS going bad but I could imagine they do because it is an electronic.
What's the part number for them I would like to get one before it quites working on me.
5,911
Looooooong ago when my dad put one of the first PPE duramaximizers on his truck (now mine), he toasted a TPS sensor. dunno if it had anything to do with that or just a bad TPS but never had an issue since. So i could believe it going bad.
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
Your truck doesn't have a TPS, it uses an APPS. Basically the same thing, but for 01-05 trucks it has 3 TPS sensors inside it(06-10 is 2 sides). You need to log all 3 APPS outputs and look for variations in them. Also don't rule out poor connections. You have the plug at the APPS(throttle pedal), and that is part of about a 2' long harness that goes up to a firewall mounted connector under the hood close to the master cylinder IIRC.
