I thought I would start to compile a list of all the necessary items to rebuild a stock motor, (everyone knows the main parts of a basic "built" motor) This is all the "other stuff" I could find, mind you this is not from experience, just a complied list of what other people have listed.
Parts from GM
-New fly wheel bolts
-New cam bolt
-Side cap bolts
-Gm sealant "Black stuff" ( 1 to 2 tubes)
-Oil gallery plugs
-Injector return line seals
-Front and rear main seals
-Front and rear cover O-rings
-Water crossover to head gaskets
-Water pump to oil cooler gasket
-Oil cooler to engine adapter plate
-Oil pump to pick up gasket
-Turbo drain gaskets
-Head Gaskets
[U]Bearings[/U]
-Main bearings
-Rod bearings
-Thrust bearing
While your in there anyway list (if you blew something)
-Front and rear thermostats
-Water pump
- oil cooler
Machine Work
-Key cam
-Key crank
-Line bore
-Cylinder bore
-Balancing
Assembly
-Check flatness of deck and heads
-Piston protrusion
-Crank end play
Once you start to add "Performance Internals" to the list, it can get very long....
Parts from GM
-New cam bolt
-Side cap bolts
-Oil gallery plugs
-Head Gaskets
[U]Bearings[/U]
-Main bearings
-Rod bearings
-Thrust bearing
-Water pump
- oil cooler
Machine Work
-Key cam
-Key crank
-Line bore
-Cylinder bore
-Balancing
Assembly
-Piston protrusion
-Crank end play
