The Smell of Fear!! (Smack Talk)
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
This will make for a fun event rather than the other way.
Yup! I need to get Casper in shape for the showdown! :box: :D
It's running 5 miles each morning, no alcohol, only Diet Diesel fuel.:driving:
Biggest problem is that it only weighs 6400lb.
Need to figure out how to add 1600lb.
:thinking:
Certainly the 3.42's and drag suspension ain't going to help much either.
bullfrogjohnson
Big Girl!
Nov 20, 2006
4,167
Locust, NC
You need some solid suspension stops and 1600lbs of tractor weights:D
or you could be underweight and still whoop up on everone, this past weekend I was 400lbs underweight
RENODMAX
Dead Wrong
Mar 4, 2008
3,602
:thinking:
Mats got to have at least that much weight in koolaid...
552
:thinking:
block for the back
rear hitch
soem good sticky dirt tires and
weight for the front
DS loops/ujoint shield front and rear
im sure you can make 3.42s work pat :poke: i know some the dodge guys are running 3.55 and doing well at
you got everything else done
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
block for the back
rear hitch
I think my strategy will be to put cases of beer in the bed, put the hitch back on, and do a 3000rpm boosted launch.
Should I run in 2WD? :D
ecc_33
Junior Member
Aug 10, 2006
1,925
Amanda, Ohio
a wieght bracket would only take a few minutes to fab up! Im sure people at the pull would be more than willing to let you barrow some wieghts for it too:D I would say put some 35's on the stock rims and let it rev to the moon....Make sure you take a video:D
SIKDMAX
Highway Burnouts!
Sep 14, 2007
4,698
Central Coast, Cali
www.sikdmax.com
By my calculations, thats 180 gals of Kool-Aid... although that doesn't count the container.... I'll donate the 360 packets of kool-aid flavor, as long as you don't mind a mix.
THATS PERFECT! 180 gallons at 8 pounds a gallon... PAT! We got 1440 pounds of Koolaid and probably 150 pounds in a container - you're set for max weight! :rofl::rofl:
RENODMAX
Dead Wrong
Mar 4, 2008
3,602
See I knew Mat would get that handled. :D
RENODMAX
Dead Wrong
Mar 4, 2008
3,602
Need some Kool-Aid stickers on the sides of the tank.
That would be just about (3) 55 Gallon drums if we can't get a skid tank.
Good photo op. :D
That and lets get you some quick release turbo kits so you can put in a stocker for tech and such, then just snap in a GT58 real fast, i think that would be more the type of playing field that youd be in dealing with those guys :D.
Arcing
<--Moms Josephs Coat Rose
:D
Here we go...
