the build
MD-Dmax
Jan 6, 2010
318
figured i would start a thread about my build, last february i cracked a piston and the build is just starting to get close, the block had to be bored .20 over, i am using socal pistons, crower rods and i put studs in everything possible, the heads will be stock with a set of beehive springs, the cam is also stock, the fueling side i am running a fuelab lift pump that feeds ppe dual fuelers and 100% over socal injectors, on the air side of things i a running a 4094 over a custom gt5088 ( it is in between a 4718 and a 5588) dustin from diesel addiction will be doing the tuning and beefing the trans up, the truck will be driven rarely since my girlfriend decided she didnt want the babies in the truck so now we have to get her a new car so she will stop complaning about the money ive spent
custom8726
2,784
Upstate N.Y
Sounds like a solid build man:thumb: Dustin seems to really know his way around these Duramax/Allisons, so between what you listed above and Dustins Help it sounds like its going to be a interesting race amongst us come july ;) :D.....
MD-Dmax
Jan 6, 2010
318
got you shaking in your boots now dont i :hug:
UPnGONe
Jul 23, 2008
196
The shore
cant wait to see this thing run :thumb: and to finnaly see this come together, got a lil project going on right now in the shop;)
MD-Dmax
Jan 6, 2010
318
go up to johns and you can see it, did you guys fix kennys headgasket problem
MD-Dmax
Jan 6, 2010
318
photo.php
turbos are here
MD-Dmax
Jan 6, 2010
318
the big charger is what forced inductions calls a compact gt55, its a gt5088
its a 89.xx mm compressor wheel and a 120mm turbine wheel, it is supposed to flow 154lbs a min, it is smaller in size then a s480 but it out flows it, the 4094 is a basic 4094
