So i picked up a junker for parts for my 1974 gm truck, 3/4 ton. my truck currently has a 383/th350/np205 the junker has a 454/th400/205.
looking to turn the 454 into a 500-600hp 496 hopefully around 600 ft-lbs.
the truck weighs about 6200 lbs, 4.56 gears, 35'' tires. also about to put an all steel flatbed on it, and plan on beating on it
I have been reading up on kits for the last week or so, searched around on here a bit, but most on here are more for a duramax
so far I know you need to upgrade from the 8/16 element sprag to a 34 element sprag
I was also thinking of adding an 300M input shaft, I have one in the Th350 now, because i twisted off the stock one at one point.
heres a couple kits im looking at
https://transmissioncenter.net/shop...evel-2-th400-terminator-transmissions-k400l2/
^^^^has 34 element sprag
https://transmissioncenter.net/shop...our-level-3-th400-raptor-transmission-k400l3/
^^^ that one is probably overkill, comes with a billet input shaft and a billet forward clutch hub, 34 element sprag, red altos
^^^ that one has red altos and the 34 element sprag
dont know much about either company, both seem to have good reviews.
Anyone have any suggestions of what i should put in this thing? or other places to check for a a rebuild kit
