Well someone on an Airboat forum is trying to sell these engines for 27K. They have a list of parts that were used.
C.I.D: Stock bore and stroke 403 C.I.D. DuraMax Diesel
Cam: Stock
Pistons: Modified Stock
Rods: Howard's
Crank: Stock
Heads: Ported
Intake Manifold: stock modified by ZZ Custom Fabrication
Oil Pan: ZZ custom Fabrication
Fuel Injection pump : Industrial Injection
Fuel Lift Pump: FASS-Fuel Air Separation Systems
Injectors: Industrial Injection +30%
Water/Meth Injection: Snow Performance
Air Intake: K&N Filters
Mufflers : Spin Tech Mufflers
Exhaust piping: 4" oval by Spin Tech
Exhaust Manifolds- BD Diesel Performance
Turbocharger: Industrial Injection Phatshaft 71
Turbo Blow-off valve: HKS Sequintial
Turbo Wastegate: Engineering Diesel 50MM
Turbo Wastegate Adaptor: Engineering Diesel
Radiator: Meziere
Fans: Spal
Water pump- Meziere Electric
ECU: MDE
Battey: Interstate
Alternator: Denso modified by Mike Abney
Fuel cell: Maxx Performance
Nitrous System: Nitrous Express NXD 5000
Progressive controller- Nitrous Express boost referenced
Vehicle Driveline:
Converter: Coan Engineering Lock-up
Transmission: Full manual 4L-80 w/trans brake
Rear: DTS Custom Shop 9" Ford W/Strange 40 spline axles and Aluminum Ultra Case
Differential: Strange light weight 40 spline spool
Gear Ratio: 3.25
Vehicle Chassis:
Roll Cage: Wolfe Race Craft 25.5
Suspension:
Front Springs/Coilovers: AJE
Front Struts/Shocks: AJE
Rear Springs/Coilovers: AJE
Rear Shocks: Strange single adjustable
Anti Roll Bar: Wolfe Race Craft
Rear Links: Wolfe Race Craft
Front K Member: AJE Tubular
Vehicle Wheels, Tires, and Brakes:
Front Wheels: Weld Magnum P.R.O. 3.5 X 15
Rear Wheels: Weld Magnum P.R.O. 12 X 15 Double Bead Lock
Rear Tires: Mickey Thompson ET Street Radials 315 X 60R 15
Front Tires: Mickey Thompson ET Street Radials Front runners
Front Brakes: WilWood
Rear Brakes: Strange Engineering
Brake Lines: Custom stainless steel by MWR
Vehicle Interior:
Seats: MAXX Performance
Black carpet
Interior Work Done By Mike Abney
Gauges: Autometer gauges, oil pressure, boost, trans temp, water temp , fuel level, volt meter
Tach: Stewart Warner
Steering Wheel: Grant Products
Seat Belts: Impact Race Products
