Testing Injectors?
DuramaxTireSmoker
Jun 8, 2010
339
SW Florida
I have checked the balance rates with my v2 and some of the injectors are in the +/- 3 or 4 range. I would like to send them off somewhere to get physically tested. Is it worth it to do this? What would it cost?
6,081
Yes send them to exergy it cost around 500 to test and balance them iirc could be wrong on that but thays what i paid couple times greg is a great guy as well as harvey
thats all? i was expecting more. Jake, any ideas what turn around time is and some cost may be if a few injectors are on their way out the door? i may have to just send mine in while they are out
DIESELMAFIAPER.LB7
<----new hotness
Jan 17, 2010
5,163
12
idaho
I can call tomorrow and ask for ya, usually its a week an a half or two weeks depending on what they find. mine i have sent have been around two weeks total time :hug:
and for what they do its cheap just to check them is around 240-260ish and then the balancing was around the same cost
schulte
Jul 31, 2010
449
CT
3 or 4 isn't bad at all. I wouldn't bother.
But if you do end up sending them for testing, Guy at Socal does testing.
6,081
sure isnt but is a slippery slope from there. its basically your early warning sign telling you you need to start thinking about injectors and save your pennies. its not like they will ever get better unless your part of the 1% were it was bad fuel.
wilsonck
May 8, 2008
206
Calgary, Ab
You could also use the dvt's to ramp pressure up to 160 and log it. This will help find one that may be weak.
Sent from my HTC Desire using Tapatalk
