LB7: Testing injectors with PPE tuner?
77cruiser
103
5
Frost Bite Falls
My 04 has started smoking a bit at idle after warming up, so I put the tuner on to check the injectors, number 2 was showing a way lower number than the rest. Does that mean it's on the way out? I don't know what the numbers mean, I'm guessing it the open time.
dirtydmax
<---up shit creek
Sep 1, 2013
1,091
46
muskoka,Ont Canada
Cant check it with the ppe,need a tech 2 or efi live to check balance rates.And the lower the number the better,0.0 being the best,the higher the # weather its - or + the worse it is.You own a lb7...better get good at changing them injectors out or have deep pockets.hope this helps.
SilveradoTwins02
Hopefully twins soon
Aug 5, 2014
194
Hanover PA
I has been awhile since I looked at the data screen on the PPE I have and the truck is apart now. But I thought I remember seeing the balance rates on mine. It lists the cly# and rate from what I recall. Year or so ago before the head gaskets went out I remember checking them.
SilveradoTwins02
Aug 5, 2014
194
Hanover PA
I gives numbers like this.
#1 inj. 2.5Ms
#2 inj. .7Ms
Just an example not the actual numbers, I should have wrote them down.
I may be wrong and someone please correct me if so. But those are the milli seconds readings. ( Balances rates). Should be between -4.0 to +4.0.
If that's not correct then I hope someone chimes in.
