Is there a way I can ramp up my fuel pressure to see if my fpr is good or bad, sort of like unplugging the sensor? At idle I always see 4,300psi of rail.every tune reads that at idle,while I hear of other people seeing 5,000psi? I mean it's higher when it hasnt reached operating temp, but thats normal. I need to know if my fpr is causing me to not get the desired rail pressure or is it the cp3. I was hitting the end of the track at only 19,000 psi with a desired of 26,100 last night!
