I know its not 100 percent accurate but the nearest track is 2 hours away and before i make the trip i wanted to do a few test runs so i used my bullydog monitor to record times and a couple of empty back roads and got 13.19 at 101 mph. Launching sucked, the monitor would read movement while trying to spool it up so i could only hit like 6 psi and my tire pressures were not lowered. When i go to the track i plan on lowering tire pressures, lowering the t-bars, and removing the hitch, rear bumper, tailgate, one battery, the spare, and my subs. So do you guys think ill be able to run mid to high 12's with that setup at the track? Any opinions, suggestions, hints, or tips are appreciated.
