Help: TEKONSHA Prodigy P3 Issue
E.carter
637
42
Princeton, Iowa
Hey everyone.... I towed a camper to scheids over the weekend and my trailers brakes worked flawless, ran b2 boost level with 2.8 gain. When I went to leave sunday after noon I found that they were not working. I stopped and checked everything over and found that I didnt have voltage present at the controller when the brake was depressed according to the trouble shooting page. I could slide the manual knob and they worked manually. I pulled the controller and harness out tonight and checked continuity between plug ends and all is fine. Anyone have any ideas as what to go after? Will try to check output from brake pedal tomarrow night. Thanks in advance, Eric
SIKDMAX
Highway Burnouts!
Sep 14, 2007
4,698
Central Coast, Cali
www.sikdmax.com
Sorry for OT, but you run 2.8 gain? Is that the one that can be set up to 12.8?
Im having an issue with a 28 foot enclosed trailer surging.... I brake and anytime it gets above about 3 it goes OVERLOADED NO BRAKES and releases braking, the grabs again, , then goes OVERLOADED, releases, grabs, etc. Surges.
Not sure what the issue is there.... yours sounds like it may be a controller issue?
WSUcowboy
500 club baby!!
Aug 7, 2006
512
Spokane, WA
where did you buy it? All P3's are still under warranty, they havent been around long enough to go out of it. They are so easy to R&R you should just swap one and see if that solves the problem.
WSUcowboy
500 club baby!!
Aug 7, 2006
512
Spokane, WA
how much weight is in it?? and are you using the P3 or the factory controller?
SIKDMAX
Highway Burnouts!
Sep 14, 2007
4,698
Central Coast, Cali
www.sikdmax.com
This is on a shop half ton. Empty trailer, thing is light. Its a P3. It was having issues so I put a P3 in it and still doing it, so I think it may be wiring related on the trailer. Its going to the trailer shop in the morning to have them do a once over on the thing before we leave for a big trade show hundreds of miles away.
But, FWIW I will be pulling it in my 08 LMM equipped with factory controller. Now, if I can get it to work is a different story, never have lol.
13,712
773
I think I read something about a guy having the same problem on his truck a week or so ago. I think it was the third brake light fuse blown that caused the problem.
trailerpro
Junior Member
Aug 6, 2006
150
Salem, Ohio
Sounds like you have a wire inside the drum rubbing on the drum or the crossover wire in the axles rubbing. Those are the two most common places to get a short. Could just be a worn out magnet too. When they wear down to the copper windings of the magnet they will short.
That is definately the first thing to check. CHMSL fuse (center high mounted stop lamp).
E.carter
637
42
Princeton, Iowa
Thanks for the replys guys. I will ckeck out the stop lamp tonight when I get off work. As far as other questions on the p3 I am a first time user of it and am not sure on the settings yet but I know with the setting I had on the trip down it worked perfect.
E.carter
637
42
Princeton, Iowa
Third brake light works just fine:( Anyone have any more suggestions? I didnt get time to check voltage output on the signal wire. Very busy nights with home remodel and baby about ready to land. Thanks
