Help: Tech 2 and tis2web
rgullett83
1,607
Illinois
Looking for some assistance. I have computer issues communicating with my tech 2 for, updates and factory programming. I got a new pc from a local computer store. I had them install a serial port, so I could use the rs-232 cable and adapter that came with my tech 2, however I cant ever get the pc to recognize the tech 2. If I go into device manager, it says the port is operating as it should. So I have an old Belkin (f5u409 i think) usb to db9 adapter. I can get the tech 2 linked up with it, but it takes forever to upload info to the tech 2. Like 3 1/2 hours for module programming, and over 30 hours for software upload, where as if i take it to the dealer and use their computer 5 -10 minutes for module programming and 20 mins for software updates. Now keep in mind I am not very computer savvy so any help will require laymans terms lol. So any and all help or suggestions will be appreciated.
juddski88
Freedom Diesel
Jul 1, 2008
4,657
120
Chesterfield, Mass.
I could not get mine to communicate through the serial port either, i tried to search for driver info to see if maybe i had not installed the driver for the port, but it was installed...not sure what the deal was. I guess I don't know how to use that port for any transfer.
rgullett83
1,607
Illinois
glad I am not the only one tim. I should also note I used a different dealership this past weekend to get my ecm programming and they are using a usb adapter as well, a different brand than what I am using (keyspan maybe?)
rgullett83
1,607
Illinois
Also I should note that I did do pass thru programming on a 2008 tahoe with my old pc and used the serial port on the pc, with no issues. That was an old slow hand me down pc at that.
GMC_2002_Dmax
The Still Master
Do yourself a favor and get a Mongoose VPW/CAN usb cable.
Run WIN-XP on your PC, direct TIS to ECM Programming at high speed without using the Tech2.
I have a Mongoose Pro Cable and a Mongoose VPW/CAN.
The Pro is not compatible for some reason with LS1/LB7 but works perfect on all other models, I am trying to sort out what Drew Tech screwed up with the pro drivers vs. the older Mongoose Cable drivers since the summer.
Plan on about $500 per cable, you should be fine with just the VPW/CAN if you can find one for GM.
:thumb:
