Tcm torque table
tractor
293
9
59
Spring Creek,NV
If I was to drop the torque in the tcm trans table would that keep the trans from going into limp mode no matter what tune I was running.
I am just thinking out loud.
Thanks Darryl
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
Thanks Darryl
Simple answer is no , it would stop the fueling tables from ever making more power because you would never hit full fuel , so any tune you flashed would be over ridden by the tcm / base torque/ TLIQ .
The truck doesnt know how much torque it makes , there is no torque sensor any where to be found , the torque #'s you see in tuning are simply hypothetical #'s used for fueling reference .
[email protected]
cmitchell17
Sep 8, 2008
251
Wait, is the torque limits table in the tcm what torque the tcm wants the engine to make during a shift defuel? So during a shift at 3100rpm the tcm wants the engine to make 494ft.lbs.?
If I am right this whole defuel thing is going to make a lot more since.
Does it take the trans torque limit table and call it DMAX Max Torque?
So when you see DMAX Max Torque drop during a shift it is referencing the torque limits table in the tcm?
But what does the ecm torque table do?
TrentNell
Jul 7, 2008
7,543
slc tuah
Go do some testing , that will tell you everything you need to know .
