TC Won't Stay Locked With EFILive Tune
duramaxdiesel
Dmax Nut
Oct 23, 2008
1,378
47
Montreal, Canada
I'm just curious if any of you guys have had a issue like this or know someone who has? On the stock tune my truck shifts and drives perfectly. When I install a tune it pulls very well and I'm happy with that. What I don't like is that when I drive and the TC is locked the second I lift my foot off the throttle the TC unlocks. It will lock up again if I get into it. I could be going 70, 80 or whatever speed and it still unlocks when I lift my foot. Really annoying when I'm towing. I tried Tow/Haul and it works intermittently at best. Even using Manual Mode I get the same results.
The truck is a 2008 LMM. All stock other than a CTS for gauges and a DPF delete tune with some more HP for towing and all around fun.
If any of you guys could shed some light on this I'd really appreciate it:thumb:
Thanks,
Nick
13,684
734
You need to check all the TCC apply and release tables and also the TCC max and min duty cycle tables.
duramaxdiesel
Dmax Nut
Oct 23, 2008
1,378
47
Montreal, Canada
Thanks Josh. I'll have my tuner check that out and see what he says:thumb:
Tomorrow I have another big load to tow and having this happen all the time is a PITA.
Nick
paint94979
Beer Nazi
Sep 18, 2006
11,715
Who tuned your truck? My apply and release tables are quite modified... That's what it took to get my converter to lock before 4th gear
SSchmi5519
LLY Cult Leader
Oct 19, 2008
3,387
Arizona
I did. He's reading lockup on an Edge CTS, and I wasn't quite sure if that was the problem. It happens on his DSP5 and on a single tune, both of which were created with his original stock tune. I have a few more ideas on how to go around this, just need a little time :thumb:
Its just very strange to me that this is happening. Cant say ive even ever heard of it :shrug:
C.bowles2
2005 lly duramax
Nov 16, 2013
489
Ohio
I wish I could help but I have a quick related question (sorry not trying to hijack the thread) when should the TC lock up, on my lly it only locks in 5th gear & at higher speeds and I can feel it lock in and lower the rpms. I'm reading it with a cts.
Dozerboy
4,892
470
TX of course
If your not in TH that sounds right
13,684
734
2008 trucks used the A40, so unless someone changed it (which wouldn't make much sense), that's what it has.
Harbin_22
3,858
Southern Indiana
Haha, I know of at least one truck that is lol. I swapped mine with a local farmer and he no longer owns the truck. If somebody ever tries to mess with it, they will be all screwed up
meshanic
All In Trucks
Dec 9, 2010
436
West Texas
Ha Ha I had an 09 LMM with big twins I was tuning so I swapped the tcm with a farmer's 08 tcm. Now there's 2:D
13,684
734
Ok, as long as the truck wasn't owned by some farmer... :roflmao:
jkholder09
Jan 8, 2012
1,188
Maryland
Well I was kinda thinking it was a measured torque issue (I am not sure what the technical term is, but I am referring to the al50 and how it determines engine torque based on trans slippage) maybe but the al40's really don't do that feature in the strategy from what I understand.
Do you think that could effect drivabilty?
13,684
734
I've never heard of the TCM doing that, but I've never played with the A50 TCM any.
jkholder09
Jan 8, 2012
1,188
Maryland
Ben tyler was talking about it somwhere.
I just can't remember where.
I have no idea if it would create a problem like this.
It was jjust stuck in the back of my head and I thought I would ask.
Thanks josh:thumb:
