Allison 6sp: TC Slip
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
Well I logged it about 2 months ago and the most slip I saw was about 250, just today it was 716 :eek: I knew I was hurting the trans with my mods from the start and I don't care I'm saving up now. I just can't believe its so much worse because I have Co Pilot now.
Is that what you would call a smoked converter or just a slipping one?
It doesn't effect the DD part, just WOT. If I keep it up though, can it get so bad that I won't even be able to drive like a civilized person?
15,681
250 rpm slip indicates converter clutch is not even coming on. Suprised it didn't code.
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
what do you mean 5-speed duty cycle?
please dont say you programmed in the 5-speed duty cycle table into the 6-speed TCM tune... :eek:
Yes, that is exactly what I did. I figured that 97 lock up would hold better than 62 in a worn TC. Is it really that big of a problem? I haven't seen anything that would make it seem like it was a bad idea
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
the 5-speed and 6-speed tcc solenoids are quite different....dont you think there is a reason allison configured the tcc solenoid duty cycle tables completely differently. ;)
you might have burned out the tcc solenoid.
ben
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
If that was the case don't you think I would get one of these codes?
P2769 Torq Conv Clutch Circ Low
P2756 Torq Conv Clutch Press Ctrl Solenoid
P2757 Torq Conv Clutch Press Ctrl Solenoid Ctrl Circ Perf or Stuck Off
P2758 Torq Conv Clutch Press Ctrl Solenoid Ctrl Circ Stuck On
P2759 Torq Conv Clutch Press Ctrl Solenoid Ctrl Circ Electrical
P2760 Torq Conv Clutch Press Ctrl Solenoid Ctrl Circ Interm
P2761 Torq Conv Clutch Press Ctrl Solenoid Ctrl Circ/Open
P2762 Torq Conv Clutch Press Ctrl Solenoid Ctrl Circ Range/Perf
P2764 Torq Conv Clutch Press Ctrl Solenoid Ctrl Circ Low
Jun 28, 2007
3,259
NE Pa
Well I would start by putting the correct duty cycle back in and seeing what happens.....
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
I think you really messed up a good portion of it (either the converter, the tcc solenoid, or both) by messing with the tcc duty cycle programming... :(
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
Hmm well if thats the case so be it. I am saving up for a ppe trans kit now. Like I said its drivable, just not the fastest thing anymore. Anyway to test the solenoid?
