Tapshifter no shifty
Budneeds2beers
Aka Mike Honcho....
Aug 25, 2016
497
Cali
Hey all. Well i installed a new tapshift kit yesterday, and when i was done it had a no start no crank situation. Ive searched through the forum and only found one post that sounded somewhat similar to my problem. Well here is where im at. When i go to start the truck the key turns over but no cranking, the volt guage is all over the place (kinda jumps around) and my fuel light is on and says my tank is empty (just pumped 28g yesterday). I did notice the dic has all the gears on it but no line under anything to signify what gear its in. Went through the instructions again and rechecked my work by pulling the tcm. checked pins, connection seats, rub, and connectors. When the starter didnt crank i did put a battery charger on it. I also haven't tried disconnecting both batteries to see if that clears anything up. Any help will be great. Thanks in advance for any info.
Budneeds2beers
Aka Mike Honcho....
Aug 25, 2016
497
Cali
Ive checked the connections again and ive even started removing the tapshifter. I put it back to stock but im having the same issue accessories come on but fuel is still telling me the tank is empty. When i move the shifter my backup horn isnt coming on(like it doesnt know what gear its in). Maybe grounding but im not seeing anything loose ,hanging we did have to remove the steel colum rt under the steering column
Budneeds2beers
Aka Mike Honcho....
Aug 25, 2016
497
Cali
Ok ive checked the fuses and its not throwing codes??? I guess ill have to call fleece and see about tech support.....:banghead:
Budneeds2beers
Aka Mike Honcho....
Aug 25, 2016
497
Cali
Ok so ive checked everything i can think of following the instructions to a T. Then i noticed they say 01-02.... i needed 03-05 so i looked on fleeces website to check those institutions and yeah there different then what the 01-02 says. So now the truck is getting a no start when i put it back to stock... well i geuss ill wait till the morn to call fleece and see how bad it is. Well i guess its beer time till then. :doh:
